NASA Solar Flare workflow, output: error in PostBin node
As a newbie with n8n, I’ve started to create a workflow from: A longer introduction | n8n Docs
all went well until the: Step six: Output data from your workflow, point 9 and 10, adding the expression: {{$json[“classType”]}}
In the previous point 7 I’ve pasted the Postbin ID into Bin ID but in point 8 I needed to configured the data to send to Postbin within the Expression tab and open the full expression editor.
Here, I think I’ve made a mistake as apparently I can’t have booth data in the expression tab: the Bin ID and the expression from point 10 ( {{$json[“classType”]}} ) . After I’ve added booth data, the Bin ID and the expression the error has appeared: :The connection cannot be established, this usually occurs due to an incorrect host (domain) value.
I’ve tried play with it in multiple ways: to leave only one of the 2 expressions either the Bin ID or {{$json[“classType”]}} , or There was a solar flare of class {{$json[“classType”]}} but I’m still getting the same error. I’m stuck and I need your help.
Could you please help me understand and solve this error?
  "errorMessage": "The connection cannot be established, this usually occurs due to an incorrect host (domain) value",
  "errorDetails": {
    "rawErrorMessage": [
      "getaddrinfo ENOTFOUND www.postb.in",
    "httpCode": "none"
  "n8nDetails": {
    "nodeName": "PostBin",
    "nodeType": "n8n-nodes-base.postBin",
    "nodeVersion": 1,
    "resource": "bin",
    "operation": "get",
    "itemIndex": 0,
    "runIndex": 0,
    "time": "8/21/2024, 1:05:02 PM",
    "n8nVersion": "1.54.3 (Cloud)",
    "binaryDataMode": "filesystem",
    "stackTrace": [
      "NodeApiError: The connection cannot be established, this usually occurs due to an incorrect host (domain) value",
      "    at RoutingNode.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/RoutingNode.js:175:23)",
      "    at processTicksAndRejections (node:internal/process/task_queues:95:5)",
      "    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:779:23)",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:51",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1104:20"
Item Index
0
Run Index
0
Node type
Node version
1 (Latest)
n8n version
1.54.3 (Cloud)
Time
Stack trace
NodeApiError: The connection cannot be established, this usually occurs due to an incorrect host (domain) value at RoutingNode.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/RoutingNode.js:175:23) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:779:23) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1104:20
  • **n8n version: 1.54.3
  • **Database: SQLite
  • **n8n EXECUTIONS_PROCESS setting: default
  • **Running n8n via: n8n cloud
  • **Operating system: Windows
Hi,
I’ve provided the information in my question, and I also don’t understand why the beginning of my question does not appear in my post.
This is my n8n setup:
As a newbie to n8n I wanted to create the following workflow:
This is the first part of my message that wasn’t posted in my first post/question.
hello @ClaudiaOz
Seems an issue with the node. Mine is not working either
@Jon @netroy fyi
This likely related to the DNS configuration on n8n cloud instances. I’ve asked the infrastructure team to have a look.
We’ll update you once this is fixed.
Many thanks, netroy!
Hi folks! Sorry for the delay. We have reason to believe some DNS requests would’ve gotten blocked due to a security feature in one of our upstream DNS servers.
We have just deployed an update to the DNS configuration. @ClaudiaOz & @barn4k, would you be able to restart or upgrade your instance from the Admin panel and let us know if this fixes the issue for you?
I was able to get it to by going to the PostBin website and create a bin and get the bin number.
but goes away after a time and i cannot get the postbin node to creat a new bin to get a new bin number
