I am building an Agent that search the Product in the Product Master of SAP system by passing the Product ID. How di I retrieve the Product Id from the chat?
Could you please help me more here? how do I extract from the chat and how do I pass it on the HTTP call? anyway I can share my project and you can help?
There is an AI node called Information Extractor,
You provide it with text and specify the attributes you want to extract from that text, such as Product ID
You can share your workflow here or provide screenshots of your workflow logic..
Thanks @Harsh_AI for the details, It’s a simple workflow, so we can ignore the information extractor and rely on the agent to extract the product ID by adding the HTTP tool and using {{ $fromAI('ProductID', ``, 'string') }}
Here’s an example you can make like this or use as a reference:
