Need Help build an AI-powered cold calling notes workflow in n8n
Hi n8n community!
I’m trying to build a workflow in n8n (local instance) that automates creating “cold calling notes” for prospects, and I could use some guidance or collaboration from someone experienced. Here’s what I want it to do:
Objective:
Given a list of prospect interior design companies , the workflow should automatically generate a structured note containing:
– Prospect Note –
Design Project:
  • A specific, completed interior design project from the company’s website or portfolio.
  • Example: "The Gilded Nest" — the actual name of a project they have done, not just a type of project.
Focus Area:
  • The main specialization of the prospect.
  • Examples: Residential, Commercial, Luxury Interior Design.
  • This should reflect what kind of projects they focus on, based on their website, portfolio, or LinkedIn.
Social Media Presence:
  • A summary of the prospect’s social media activity, ideally for Instagram, LinkedIn, or other relevant platforms.
  • Includes:
    • Activity Level: High / Medium / Low — based on number of posts, engagement, or general activity.
    • Followers: Number of followers (approximate is fine).
  • Example: "High activity" - 12,000 followers
The notes should be concise, standardized, and ready for cold calling outreach — really simple and easy to read.
EXAMPEL :
Desired Workflow Steps:
1. Input
  • List of prospect companies via Google Sheets.
  • Include fields such as: website link, Facebook link, LinkedIn link, business name, owner’s name, etc.
2. Search / Data Gathering
  • Ideally, search for information automatically using the website link (e.g., Redirecting... ).
  • I think there’s a node that can perform searches or fetch website data.
3. Summarization via AI (my biggest challenge)
  • Use OpenAI GPT (ideally GPT-5 mini or GPT-4) to filter and structure the information into the note format described above.
4. Output
  • Save the structured notes to Google Sheets, CSV, or Notion for easy access.
  • Notes should appear in a column to the right of the specific prospect.
Optional / Advanced:
  • Include a web scraping step to automatically check Instagram or LinkedIn for social media activity.
  • Rate social media activity as High / Medium / Low based on followers and post frequency.
What I’m Looking For:
  • Tips on prompting GPT to consistently return structured notes.
  • Advice on optionally integrating social media metrics.
  • Any workflow templates or examples that are similar
Thanks so much in advance! I’d love to collaborate or see any examples of workflows like this.
Hi @Oliver_Beier
Look for templates related to AI, OpenAI, Research, or Lead Enrichment in the n8n templates gallery. Even if they are not “cold calling” specific, the structure is the same and can be reused.
For all LinkedIn related outreach and gathering profile info, do take a look at this Node
