Need help building a work flow and i am stuck, please help
Hello,
I am very new to n8n. I am trying to build a work flow.
Upload a photo to a specific Google Drive folder → n8n detects the file → runs an automation create video, post to Facebook and TikTok.
I added Google Drive trigger, added 2 photos to the google drive. set up my nextsteps, down load from Google drive. This where i get stuck, i am trying to add the file by ID, and looked at the Google trigger, and was looking for the ID in the space, but there is nothing there, did i do this correctly? Please help
Hey @Kevin_Mun hope all is well. What did you setup so far? Would you like to share?
So I understand you want to be able trigger the flow with the upload of a file to google drive (“on change to a folder” operation), so you set up a trigger and having issue with configuring it? You can specify a folder where you want to be watching for a file and what type of operation it needs to be watching for. Do you get an error or something? What is not working? How is it not working exactly?
in the Google drive trigger, it does not show me the ID in the spaces, i need the ID to enter at the Google Drive file down load step.
w the ID
I don’t know what i did wrong, thank you so much for helping me. :slightly_smiling_face:
