Need help designing the workflow for Course 2 quiz. My Airtable credential is not being accepted.
Hey @maryoneil !
Do you use Personal Access Token?
Be sure check scopes and access when creating your PAT in Airtable, you must give it at least these scopes (recommended by n8n):
data.records:read -
data.records:write -
schema.bases:read
And you must grant it access to the base/s or workspace you want to use.
Cheers!
Thank you when I get the node, do I get many bases, or get base schema? or get a record? Also don’t see the PAT i created in the dropdown list.
Mary
How do I grant access to my base “course 2 wkfls”?
Hey @maryoneil !
In the Airtable platform you have to give scope access.
In n8n looks good what you are trying to do.
What about your credentials?
