Need Help - Deployment
Hi,
Created 1st chatbot and when I set the workflow to active and make the chatbot publicly available and click on the url, obtain the message :
This sustainml.app.n8n.cloud page can’t be found
No webpage was found for the web address: https://sustainml.app.n8n.cloud/webhook/aaa4a2eb-d52c-463c-8821-8c7197922cfe/chat
HTTP ERROR 404
I am currently trialing n8n - all help appreciated.
Thanks in advance. Cheers!
When opening your link, it works for me:
Maybe there is something blocking it on your system?
Does it still not work for you?
fyi, the link you posted can be used by everyone who sees your post. Limit the usage of this workflow somehow or remove the link from the post aslong as this workflow/chatbot is publicly accessible.
