We recently started using n8n and are trying to connect our PostgreSQL database. However, we are unable to establish the connection because we need to whitelist n8n’s IP address. We are unable to find the correct IP to whitelist.
You can simply ping you server from a terminal, for example:
ping n8n.shivendra.com
Or you can also run this workflow:
Hello @Shivendra_Patel,
Here’s a link to the outbound ip addresses as well.
If this answer helped solve your issue, feel free to mark it as the solution so others can benefit from it too!
Best,
Robert
