Need help on "#each " HTLM code
need help on items in array and {{#each $json.output.items }} just not working
What is the error message (if any)? Syntax Error
@Ericchen The Generate HTML Template functionality in the HTML node does not support Handlebars looping such as {{#each …}} , so you need to create your repeated HTML manually, by for instance concatenating strings in a Code or Summarize node, before providing it to the HTML Template.
