Need help to connect my locally hosted n8n to Google Sheets
Do you run something like docker compose up -d to start or docker run ...?
Or maybe Docker Desktop with User Interface?
not sure how i am supposed to answer that but when i start n8n i click on containers and then there is a little launch button and i simply press that there i can entere a name and port
Ok, so you are using Docker Desktop then.
I think the screen you are referring to is as below and here (in red) is where you can specify the env vars:
Try adding an Environment variable
WEBHOOK_URL and value http://localhost:5680/
Hey we are 2 peoples and my friend cant send another message because the acc is new
Now we have the problem that i cant choose the right sheets document ( i added a screenshot)
