Need Help understanding access to nodeJs in Function Item
Hi fellow n8nians!
Can someone point me to some docs or explain what access I have to nodeJS or browser API in a Function Item(s) Node?
Specifically, I was trying to get some things like:
const fs = require('fs')
const path = require('path')
const util = require('util')
and they error out with
ERROR:Access denied to require 'fs'
What are the limitations of a Function Item Node?
Can I access nodeJs in a different way?
Thanks,
Jordan
You do not have any access to the browser API. You can however use own or built-in Node.js JavaScript libraries if you give access them:
https://docs.n8n.io/hosting/configuration/#use-built-in-and-external-modules-in-function-nodes
Thanks Jan!
And sorry, I think I knew that from a while back…but forgot.
Follow up, I think I remember some docs about adding your own npm modules to the n8n instance other than those natively included as part of n8n.
Can you point me to that?
Best,
Jordan
Is there a workaround for cloud-hosted N8N? I need to use TextEncoder but can’t require it from the util package.
