This is my AI chatbot workflow, the chatbot is fine and it can book appointments on google calendar. However, it has a bad habit of suggesting the same times for appointments in multiple conversations which results in double booking. I want to know how the bot can possibly scout google calendar and see which spots are taken and then suggest open times. I’m a beginner so I apologize if I sound stupid or am asking an elementary question
@Tentordev Here’s a complete HTML file that demonstrates how to check Google Calendar for available time slots before suggesting appointment times.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Calendar Availability Checker</title>
<style>
body {
font-family: 'Segoe UI', Tahoma, Geneva, Verdana, sans-serif;
max-width: 800px;
margin: 0 auto;
padding: 20px;
background-color: #f5f7f9;
color: #333;
.container {
background-color: white;
border-radius: 10px;
padding: 25px;
box-shadow: 0 4px 6px rgba(0, 0, 0, 0.1);
h1 {
color: #1a73e8;
margin-top: 0;
.explanation {
background-color: #e8f0fe;
padding: 15px;
border-radius: 8px;
margin-bottom: 20px;
.form-group {
margin-bottom: 15px;
label {
display: block;
margin-bottom: 5px;
font-weight: 600;
input, select {
width: 100%;
padding: 10px;
border: 1px solid #ddd;
border-radius: 4px;
box-sizing: border-box;
button {
background-color: #1a73e8;
color: white;
border: none;
padding: 12px 20px;
border-radius: 4px;
cursor: pointer;
font-size: 16px;
margin-top: 10px;
button:hover {
background-color: #0d62c9;
.result {
margin-top: 20px;
padding: 15px;
border-radius: 8px;
display: none;
.available {
background-color: #e6f4ea;
border: 1px solid #34a853;
.unavailable {
background-color: #fce8e6;
border: 1px solid #ea4335;
.time-slot {
padding: 8px;
margin: 5px 0;
border-radius: 4px;
.code-sample {
background-color: #f1f3f4;
padding: 15px;
border-radius: 8px;
overflow-x: auto;
margin-top: 30px;
font-family: monospace;
font-size: 14px;
</style>
</head>
<body>
<div class="container">
<h1>Calendar Availability Checker</h1>
<div class="explanation">
<p>To prevent double-booking, your chatbot needs to check Google Calendar's API for existing events before suggesting appointment times.</p>
<p>This demo simulates how that process works. Select a date and duration to see available time slots.</p>
</div>
<div class="form-group">
<label for="date">Date:</label>
<input type="date" id="date" required>
</div>
<label for="duration">Appointment Duration:</label>
<select id="duration">
<option value="30">30 minutes</option>
<option value="60">60 minutes</option>
<option value="90">90 minutes</option>
<option value="120">120 minutes</option>
</select>
</div>
<button onclick="checkAvailability()">Check Available Times</button>
<div id="result" class="result"></div>
<div class="code-sample">
<h3>How it works in code:</h3>
<p>Your chatbot would use the Google Calendar API to check for free/busy times:</p>
<pre>
// Pseudocode for checking availability
async function checkCalendarAvailability(date, duration) {
// Set up the request to Google Calendar API
const request = {
timeMin: new Date(date + 'T09:00:00').toISOString(),
timeMax: new Date(date + 'T17:00:00').toISOString(),
items: [{ id: 'primary' }]
// Make the API call
const response = await calendar.freebusy.query({
auth: authClient,
resource: request
// Process the response to find available slots
const busySlots = response.data.calendars.primary.busy;
const availableSlots = findAvailableSlots(busySlots, duration);
return availableSlots;
function findAvailableSlots(busySlots, duration) {
// Logic to find gaps between busy times that can fit the appointment
// Return array of available time slots
</pre>
</div>
</div>
<script>
// This is a simulation since we can't access Google Calendar without authentication
function checkAvailability() {
const date = document.getElementById('date').value;
const duration = parseInt(document.getElementById('duration').value);
const resultDiv = document.getElementById('result');
if (!date) {
alert('Please select a date');
return;
// Simulate checking Google Calendar API
// In a real implementation, you would make an API call to Google Calendar
// For demo purposes, we'll simulate some busy times
const busyTimes = [
{ start: '09:00', end: '10:30' },
{ start: '11:00', end: '12:00' },
{ start: '13:30', end: '14:30' },
{ start: '15:00', end: '16:00' }
// Generate available time slots
const availableSlots = generateAvailableSlots(busyTimes, duration);
// Display results
if (availableSlots.length > 0) {
resultDiv.className = 'result available';
resultDiv.innerHTML = '<h3>Available Time Slots:</h3>';
availableSlots.forEach(slot => {
resultDiv.innerHTML += `<div class="time-slot available">${slot.start} - ${slot.end}</div>`;
resultDiv.innerHTML += '<p>These times are free in your calendar.</p>';
} else {
resultDiv.className = 'result unavailable';
resultDiv.innerHTML = '<h3>No available slots</h3><p>No suitable time slots found for the selected duration. Please try another date or shorter duration.</p>';
resultDiv.style.display = 'block';
function generateAvailableSlots(busyTimes, duration) {
const availableSlots = [];
const dayStart = 9; // 9 AM
const dayEnd = 17; // 5 PM
// Sort busy times by start time
busyTimes.sort((a, b) => a.start.localeCompare(b.start));
// Check before first appointment
const firstBusy = convertTimeToMinutes(busyTimes[0].start);
if (firstBusy - dayStart * 60 >= duration) {
availableSlots.push({
start: convertMinutesToTime(dayStart * 60),
end: convertMinutesToTime(firstBusy)
// Check between appointments
for (let i = 0; i < busyTimes.length - 1; i++) {
const currentEnd = convertTimeToMinutes(busyTimes[i].end);
const nextStart = convertTimeToMinutes(busyTimes[i+1].start);
if (nextStart - currentEnd >= duration) {
start: convertMinutesToTime(currentEnd),
end: convertMinutesToTime(nextStart)
// Check after last appointment
const lastBusy = convertTimeToMinutes(busyTimes[busyTimes.length - 1].end);
if (dayEnd * 60 - lastBusy >= duration) {
start: convertMinutesToTime(lastBusy),
end: convertMinutesToTime(dayEnd * 60)
function convertTimeToMinutes(timeStr) {
const [hours, minutes] = timeStr.split(':').map(Number);
return hours * 60 + minutes;
function convertMinutesToTime(totalMinutes) {
const hours = Math.floor(totalMinutes / 60);
const minutes = totalMinutes % 60;
return `${hours.toString().padStart(2, '0')}:${minutes.toString().padStart(2, '0')}`;
</script>
</body>
</html>
Thank you so much for this
You are welcome and Kindly mark as solution if this was helpful to you.
