Newbie here. I'm going through the initial tutorial, and I'm at the lesson on creating the web scraper to find reviews for a restaurant. The issue is that I'm using Apify, and when I try to run the workflow it requires credentials, but there's nothing indicating what kind of credentials n8n requires for it. And the tutorial doesn't mention anything about it at all. Even the video shows the process with no credentials. I've created an Apify API, but it's no help if I can't find the specific cred type I need.
“errorMessage”: “Credentials not found”,
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “HTTP Request”,
“nodeType”: “n8n-nodes-base.httpRequest”,
“nodeVersion”: 4.3,
“time”: “1/14/2026, 9:24:13 PM”,
“n8nVersion”: “2.3.2 (Cloud)”,
“stackTrace”: [
“NodeOperationError: Credentials not found”,
" at ExecuteContext.getCredentials (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/node-execution-context/node-execution-context.ts:360:10)“,
" at ExecuteContext.getCredentials (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/node-execution-context/base-execute-context.ts:99:21)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:183:30)“,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1045:31)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1226:22)“,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1662:38”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2297:11"
- n8n version: 2.3.2 (Cloud)
- Database (default: SQLite):
- Operating system:
