Need help with AWS Bedrock HTTP Request
Using the Basic LLM chain I noticed the only Bedrock models available are the text models. I would like to utilize the new Nova Reels text-to-video model. However, when I use my saved AWS Credentials in the HTTP request, I keep getting the ‘Forbidden - perhaps check your credentials?’ error.
Perhaps this is because the hash signature step doesn’t take place when using an http node?
Anyone know a way around this?
Hi @Anthony_Lee
The signature hashing is done in the AWS Credentials but it depends on whether the service uses SigV4. We use the aws4 library and you find the supported services here:
Can you expand on the error that you’re getting? What’s the stack trace?
Hi @Anthony_Lee, good news,
we are currently reviewing a PR that adds bedrock runtime to the supported services :slight_smile:
Hey Ria, any chances for this feature get merged this month?
