Hi everyone,
I need some help with the execution behaviour in my workflow. I’m sending data from Airtable to Lovable using an n8n workflow that’s scheduled to trigger every 6 hours.
The issue is that when the workflow runs automatically via the schedule trigger, it does not fetch the new data from Airtable. It only sends the older data that was previously sent when I executed the workflow manually.
I’m not sure if this is related to execution data, node settings, or how Airtable search is handled in scheduled runs.
Has anyone faced a similar issue or can guide me on what I should check to fix this?
n8n version:
Database (default: SQLite):
Operating system:
