Need help with N8N101 Essentials course
I am facing an issue completing the N8N101 Essentials course,can anyone pls help me.
Hello,
Please outline your issue. The green ticks are only to track your progress, they do not count towards your final grades. Only the section quizzes, hands on exercises and the final exam count.
There is a known issue with the progress check marks and we’re waiting for a bug fix from the vendor.
cheers,
Thank you for replying, but I already gave the final quiz. After that, it showed that your Section 1 part is not complete, and it added to the grade as if the quiz count and the hands-on. I also have a doubt regarding the hands-on: if I create a step-by-step workflow in n8n, is that considered or not?
You must complete all section quizzes and the workflows exercises. All of these count towards your grade. Your progress is just how much of the course you have ‘read’ which currently has a bug from our LMS provider. The green checks don’t count towards your grade.
So in n8n, if I create workflow as given in the document, does it count as grading this hands-on exercise?
Yes, you must follow the instructions, call the various endpoints with the correct authentication and details and you will recieve a pass mark for each checkpoint.
Thank you so much
@idol_hutabarat In the future please start your own topics. The green ticks do not count towards your grade, only the quizzes and hands on exercises do.
cheers,
