Hello.
I’m new to n8n. Maybe this workflow is too ambitious, i don’t know : i’m trying to set up a workflow around WITHINGS data, by using the WITHINGS connectores, and i’m not able to have anything working.
Could someone point me in the good direction ?
- Which WITHINGS nodes should be installed ? This is incredibly confusing :
- There are two different community nodes (see : Search n8n nodes | NCNodes)
- There are different “oauth2” associated nodes (the “default” one and a “custom one”)
- Even worse, depending “what is installed first”, it seems the final behavior is totally different ! (the fork of the WITHINGS node and nothing else (OAUTH2 retrieved as a dependency), or first the custom OAUTH2 then one node or the one, etc.) - then some fields / buttons are available … or not !
- So what exactly should be installed, and how ?
- How to configure the OAUTH2 part regarding withings ? This is not clear at all (related to previous question : depending what is installed and even HOW it is installed, the available fields are very different)
- How to have a fully working / complete workflow ? Is there a recipe / example somewhere ?
- Which connectors should be chained / in which order / with which operation ?
- “Withings Dummy” ?
- “Withings Token Exchange” ? (with which operation ? what to input in these fields ? etc.)
- etc.
- I have of course set up a Withings developer API on their website (and the associated “credentials” part in N8N seems ok)
It’s my very first try with n8n and i have to say i’m quite disappointed by how unfriendly this is (at least for beginners). I did many tests, installing, removing, restarting from scratch, trying to configure OAUTH2 for this node … nothing worked, even after hours of testing.
Any help would be appreciated.
