Need your help with email
Hi everyone after a day i need your help to resolve this problem. I have this error problem with gmail for any type of sending and i dont find a way to resolve that. Other process acces to drive work i connect gmail to the google account and nothing work will be so happy if someone find a solution TKS
Hey! How are you hosting n8n?
Here is what I would check based on the previous errors reported in the forum:
  1. At Google Cloud Console → APIs & Services → OAuth consent screen:
    Set your app to In Production so your token doesn’t expire every 7 days
  2. Make sure the n8n redirect URL is correctly set:
    Screenshot 2025-09-17 at 4.15.49 PM
  3. Make sure you copy-pasted the client secret and client ID into n8n without spaces or typos
  4. While at it, also make sure you enabled the Drive API:
    Google Cloud console
  • If self hosted, check that these are set:
WEBHOOK_URL=https://your-domain.com/
N8N_HOST=your-domain.com
N8N_PROTOCOL=https
Thanks for your answer i did everything but nothing work do you have a discord or anything if you have one minutes to help me really appreciate thanks for your help
Could you also add the domain in Origines JavaScript autorisées, like in my screenshot
https://n8n.cloud
Hey, please check your DMs, I’m available to help you online if you need still.
