Hey I have a json like
"quantitiesAligned": false,
"quantities": {
"Movement Quantity": 3197945
I have an expression like
"text": "• Quantities aligned: {{$node["Get pipeline stats"].json["quantitiesAligned"] ? ':white_check_mark:' : ':x:'}}"
I’d like to change it so in case quantitiesAligned
is false it’d print also the $quantities.Movement Quantity
. I created an expression like
"text": "• Quantities aligned: {{$node["Get pipeline stats"].json["quantitiesAligned"] ? ':white_check_mark:' : ':x:'}}{{$node["Get pipeline stats"].json["quantitiesAligned"] ? '' : ('\n*' + $node["Get pipeline stats"].json["quantities"]["Movement Quantity"] + '*')}}"
but it’s not working - how to fix it ? Especially in if-else
when using node value how to concat a string ?
