you can use docker für selfhosting and another
Hello Experts, I am newbie to N8N, I build my 1st workflow leveraging AI Agent, which takes prompt input from a chat box (manual input) and using Gemini LLM posts output to my LinkedIn as post. and it worked after some rounds of error 403 on LinkedIn node! Now I want to automate it, so that instead of chat box manual input, the AI Agent (Gemini supported) would read the prompt from an Excel or CSV File (say in column-A, at given time stamps in columb-B) and posts automatically on LinkedIN. I could add Excel node as input to AI Agent, didnāt give any error but not processing output to post on linkedIN (like it worked with manual input), how to fix that?
can anyone help me with this?
Hey @Neil_Nileshkumar !
Try create your own topic, instead hijacking a thread that is used for another purpose!
Cheers!
Thatās great! I have recently completed Level 1 and will be moving on to Level 2. I expect to have several questions during workflow creation, and I am glad I can use this platform - particularly the āHelp Me Build My Workflowā feature; for guidance.![]()
Just automated a workflow where a new product photo in Shopify triggers an AI video generator. 10 minutes from āPhotoā to āVideo Ad.ā The tech is finally at a point where solo founders can be able to compete with big agencies.
this is helpful ![]()
Itās a good Idea for learningā¦.
Help me build my Workflow should focus on design and Architecture, but, troubleshooting is another concern⦠so, I agree with you
A post was split to a new topic: Community Nodes: āPackage has already been installedā error
Great!
I canāt agree with you anymore!
Hi, Iām new to the community! I would love any advice on the best practices to get started?
Post
Hi everyone,
Iām building an n8n workflow connected to a chatbot and Iām looking for advice on structuring it correctly.
Goal
Handle chatbot conversations
Automatically route users into two flows:
Sales (clients requesting services)
Drivers (independent drivers applying)
Log every message
Save structured data into an existing Excel file (no new files or sheets)
What I need help with
Best way to manage conversation state (
conversation_id, steps) -
How to ensure every message is logged without duplicating logic
Recommended workflow structure to keep it clean and scalable
Thatās a good approach
but Iāve found it works better to not jump straight into JSON.
First, break the workflow down in simple steps (trigger ā get data ā process ā format ā send). Then use AI to help with the logic and structure, not just to generate code.
After that, either generate parts with AI or build it directly in n8n.
