Next Form Page: Default Values
The idea is:
The Form Trigger allows default values by using query parameters. But very often in a multistep form we also need to prepopulate values. Right now the node provides a “placeholder” that is grayed out and cannot be copy/pasted and disappears when the user adds any input. What’s missing is another field for “default value”.
My use case:
I have a multistep form where I enable class administrators to edit the title and subtitle of a class.
Step 1 executes a postgres query to get the list of classes. The next step is a dropdown that is dynamically populated with the list of classes. The class Admin chooses which class they want to modify.
The issue comes up on the third page: I give them fields where they can enter the new Title and the new Subtitle. Usually those are small changes from the existing values, so I want to prefill those fields with the existing values and let them make subtle edits. But I have no way to do that. Using a placeholder is actually confusing and frustrating UX.
There are a lot of cases where multistep forms are used to modify existing data. Prefilling fields has lots of possible applications.
Ideally this capability would be added to fields of type date, text, email, textarea, and number. It probably should NOT be added to field type password.
None needed
Willing yes, able no. Nobody wants me working on code that someone else will use in production.
As a workaround, above each input field I put a custom HTML field which I populate with the current value. That works for text fields and would probably work for number and email fields, but it’d be sloppy for textarea and I’m not sure how it would work for dates.
This is a great idea. I’m just getting started with n8n, and I ran into this issue on my first form. I’m wondering if there might be a way to auto-populate a default value with a JavaScript expression, but I haven’t figured it out yet. It would be so much easier to have a built-in “default value” option.
I’ve got a form I’m trying to do this on right now, totally not realising that it’s not possible! Hoping this comes out soon!
I support this feature request. The form node should support default, label, value..
Not just a single “Field Name”
+1 Default value is very usefull. Appreciate the update, n8n!
This would be great for AI workflows with a human in the loop.
Currently, embedding JavaScript in the form’s description does somehow work, but imagine putting this in the Response Form Description:
your actual form description
<script>
document.addEventListener('DOMContentLoaded', function() {
  const fullname = document.getElementById('field-0');
  if (fullname) {
    fullname.value = "{{ $json.fullname }}";
</script>
…very hacky indeed.
This does not work (anymore), the script-element is removed.
Adding a link withhref=”javascript:…” doesn’t work too.
Great workaround and still works for me. (v1.116.2)
+1 Default value. Would really appreciate this functionality!
i would really appreciate this feature and I think, you should implement it in priority because of AI erra, we need to validate the output before doing things sensitive !
guys, i wanted to do the modification, but i discovered the code was already commited by someone else :
Thx, n8n !
