The idea is:
Add better user management for Nextcloud:
- Disable/enable users (prevent from login)
- Create/delete groups
- Change user’s groups
My use case:
I need to be able to disable/enable users and change their groups for security measures.
I find the ability to temporarily ban users and change their access very important. Currently implemented management in n8n core Nextcloud node is quite barebones, you can only delete a user, and can’t manage groups.
https://docs.nextcloud.com/server/latest/admin_manual/configuration_user/user_provisioning_api.html
No but the API seems pretty straightforward and easy to implement, for now as a workaround I will try to make api calls with curl using Execute Command nodes.
