I am successfully get a folder list from Nextcloud however, path names and file names cannot display spaces and non-English file names correctly. Instead it uses %20 to display spaces etc. so when I want to download these files, next cloud download node cannot find files because it cannot find correct file name.
Is there an easy way to overcome this problem?
I will dig into this, In theory the values are being url encoded so the %20 should be correct and work. What is the full error you are seeing when you try and what is the name of the file?
This is the full file name we tens of this like that: es/Acme/MUHA/%c3%87EK%20G%c4%b0R%c4%b0%c5%9e%20%c3%87IKI%c5%9eLARI/%c3%87EK%20%c3%87IKI%c5%9eLARI/B%c4%b0Z%c4%b0M%20KARGO.pdf
