Hello!
I am trying to upload a txt file to Nextcloud using a base64 encoded string as source, and decoding it before the save. But it ends being an blank line in the file.
My expression looks like:
{{ atob("SGVsbG8gV29ybGQh") }}
Test
The function finishes successfully but the txt file only contains the Test
line:
Test
The interesting thing is that I can see the output correctly decoded in the expression preview window.
So the issue is only when running the workflow.
None
Node config
- n8n version: 0.159.0
- Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]: main
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
