I can’t get past this phase, what’s happening?[Even after adding all the correct credentials sent by email from N8N “header auth name/header auth value” creating new credentials…ALWAYS GIVES ERROR 403…If someone can help I’d really appreciate it, my studies are on hold. Please.
Forbidden - perhaps check your credentials?
A
Hello,
The level 2 course was retired on the 30th of June. You will need to sign up to the n8n Academy and enrol in the courses you want to do. There are no emails sending you details any longer. They are all within the course content itselt. Your asssessment ID is available at the top of every page of the new acdemy.
cheers,
