No fields - item(s) exist, but they're empty - help
Trying to extract content from doc to analise but the output always comes up empty. not sure about the problem. can you help me?
RCkddoMmmOQcZvEn
Hello @WiseBot ,
Can you copy your workflow and paste it in a code block? That will help determine the issue.
Best,
Robert
```[type or paste code here](https://wisebot.app.n8n.cloud/workflow/RCkddoMmmOQcZvEn)
@WiseBot
Not the link. Select all of the nodes in your workflow, copy them and paste them in the code block. Then we can see the actual workflow.
Best,
Robert
