Does this makes any sense? Why are the base node activated?
I know the reason of the error, but the IF node should prevent this.
Hi @LeonSantiagoOmni, welcome to the community!
Are you by any chance using a Merge node further down the line? The Merge node would pull in data from both input branches, even if one of them wouldn’t run otherwise.
