Node doesn’t stop running / n8n crashes / hangs itself up
Hi, I updated my local n8n to the newest version ( 1.53.2 ). Now I have an error that in one of my workflows my Outlook-Node doesn’t stop running. I also can’t stop the workflow and in general I can’t use n8n anymore because every time it hangs itself up (Saving changes doesn’t work, etc.). I have to restart the docker container to make it work again. I tried to replace the Outlook-Node with some configurations but different name. Then it works normal, but the node after doesn’t start running. However the Outlook Nodes I use in other workflows run like it should be.
Mybe it hast something to do with a big chung of data which ist stored? I work with pdfs in the workflow, where the Outlook-Node doesn’t work. I did a lot of testing. Is there a way to clear the data out of this workflow if it is stored?
Does someone know what I have to do to make it work again?
Edit: I found out that it has something to do with the “Download Attachments” option. If I run the node without “Download Attachments” enabled, everything works. But it I switch it on, I get the case described above. However the Node with “Download Attachments” switched on works in other workflows fine (same Mail, same Amount of Attachments (just 3x)).
  • **n8n version: 1.53.2 **
Hey @prcode,
Can you share more on your configuration of n8n? The first thing I would try is setting N8N_DEFAULT_BINARY_DATA_MODE to filesystem and seeing if that changes anything.
