Hi, a question,
is it possible, that when a node entry not availabe that i get nothing instead of not found ?
Thanks,
Stefan
Hi, a question,
Thanks,
Stefan
You already do. It only displays “[not found]” in the preview window to make clear that the value did not get found. If you close the expression editor you should see that actually in the parameter on the node there is nothing.
