I am trying to get my workflow to work after the previous version update to .199. The issue seems to be that the play button on top of nodes are not executing previous nodes before it. Is this a intentional change in this update or just a bug? Also is there a place to see the changelog for updates? --Thanks
Hi same issue here, click on play on a node do weird things⌠So I need to click on âExecute workflowâ button and then stop the workflow to be able to work on the workflow like I always doâŚ
I think we were looking at releasing the new version later today or tomorrow. So, if you self-host n8n it shouldnât be much longer before you can avail of the fix.
Yes, usually a few versions behind. As this is an extra process the n8n team has to go through to release these.
I donât think there is a public release schema for these, so donât know when the next one will be out.
Bram is right, So Desktop we update when we are able to at the moment it is on 198.2 and I think there was maybe 3 or 4 months between the releases.
If you wanted the latest version running npm is fairly painless unless you use webhooks but docker on something like digital ocean works well or our own cloud offering.
