Node Triggered Incorrectly in Flow
Hi,
I’ve a worflow with several nodes and two conditional branches, two branches are executed when only one should be launched.
  • n8n version: 0.236.3
  • Running n8n via Docker on a VPS
  • Operating system: Linux
Thanks!
Hi @justincuzin ,
Welcome to the community! :dizzy:
I’m not sure I understand what you mean here. Are you saying that you expect both the true and false conditional outcomes to execute?
Could you maybe share how you’re setting up the parameters in the If Node?
You can also insert your workflow by selecting the whole thing in the editor screen and pressing ctr+c and then pasting it here after selecting </>
