Not a number when casting workflow ID to a number
Hi Community
I need help with the error: not a number when casting workflow ID to a number
I use the Plesk Linux platform, I have the almalinux 8.7 operating system and I use the Docker feature.
I used the n8nio/n8n Docker image
LOG CONSOLE
Initializing n8n process
UserSettings were generated and saved to: /home/node/.n8n/config
Migrations in progress, please do NOT stop the process.
Migrations finished.
n8n ready on 0.0.0.0, port 5678
Version: 0.207.1
Editor is now accessible via:
http://localhost:5678/
Owner was set up successfully
User survey updated successfully
Error Error: not a number when casting workflow ID to a number
Error “Error: not a number” when casting workflow ID to a number
The error not a number when casting workflow ID to a number appears when a call is executed in the application
Hey @appuni,
I don’t think the error actually causes any issues but can you try updating to the latest release I think we have fixed that one.
