Not able to merge data
This flow is supposed to send me the tasks that are overdue and are due today from Todoist. I am not able to merge both and show it on one message. I am not sure what is the issue.
  "nodes": [
      "parameters": {
        "operation": "getAll",
        "returnAll": true,
        "filters": {
          "filter": "today"
      "id": "72525a02-8f15-45de-94a2-559aef58d7ab",
      "name": "Today tasks",
      "type": "n8n-nodes-base.todoist",
      "position": [
        560,
        0
      "executeOnce": true,
      "retryOnFail": true,
      "typeVersion": 1,
      "alwaysOutputData": true,
      "credentials": {
        "todoistApi": {
          "id": "2pfirzy3hSRgtgdC",
          "name": "Todoist account"
      "parameters": {
        "returnAll": true,
        "filters": {
          "filter": "overdue"
      "id": "e872539b-a124-4670-a2d2-d71559565b87",
      "name": "Overdue tasks",
      "position": [
        560,
        200
      "typeVersion": 1,
      "credentials": {
        "todoistApi": {
      "parameters": {
        "fieldsToAggregate": {
          "fieldToAggregate": [
              "fieldToAggregate": "content",
              "renameField": true,
              "outputFieldName": "contentOverdue"
        "options": {}
      "type": "n8n-nodes-base.aggregate",
      "typeVersion": 1,
      "position": [
        800,
        200
      "id": "92c372ad-e5ab-4b08-94d4-c60c2488ce0c",
      "name": "Aggregate1",
      "alwaysOutputData": false
      "parameters": {
              "outputFieldName": "contentToday"
        "options": {}
      "typeVersion": 1,
      "position": [
        800,
        0
      "id": "320d6517-9836-44df-89e6-4d6fff9d423a",
      "name": "Aggregate2",
      "parameters": {},
      "type": "n8n-nodes-base.manualTrigger",
      "typeVersion": 1,
      "position": [
        300,
        200
      "id": "c81b97c4-1dea-48fc-bc49-90efb35cb467",
      "name": "When clicking ‘Test workflow’"
      "parameters": {},
      "type": "n8n-nodes-base.merge",
      "typeVersion": 3.1,
      "position": [
        1100,
        20
      "id": "edf3b4f5-961a-42ce-8a0a-80656695c5a3",
      "name": "Merge"
      "parameters": {
        "chatId": "924028505",
        "text": "=Todays Tasks:\n{{$json[\"contentToday\"].join(\"\\n\")}}\n\nOverdue Tasks:\n{{$json[\"contentOverdue\"].join(\"\\n\")}}",
        "additionalFields": {
          "appendAttribution": false
      "type": "n8n-nodes-base.telegram",
      "typeVersion": 1.2,
      "position": [
        1340,
        20
      "id": "848ea71d-5dec-4005-85ac-08d4691384e0",
      "name": "Telegram1",
      "webhookId": "166970a5-6af0-48ae-9926-3684fedac67b",
      "credentials": {
        "telegramApi": {
          "id": "S1ACGaxgo6cPnniq",
          "name": "Telegram account"
      "parameters": {
        "rule": {
          "interval": [
              "triggerAtHour": 9,
              "triggerAtMinute": 10
      "id": "90dbd5b6-4dee-4fb9-90fb-9b441adca001",
      "name": "Every day at 9am",
      "type": "n8n-nodes-base.scheduleTrigger",
      "position": [
        300,
        0
      "typeVersion": 1.1
  "connections": {
    "Today tasks": {
      "main": [
            "node": "Aggregate2",
            "type": "main",
            "index": 0
    "Overdue tasks": {
      "main": [
            "node": "Aggregate1",
            "type": "main",
            "index": 0
    "Aggregate1": {
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 1
    "Aggregate2": {
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 0
    "When clicking ‘Test workflow’": {
      "main": [
            "node": "Today tasks",
            "type": "main",
            "index": 0
            "node": "Overdue tasks",
            "type": "main",
            "index": 0
    "Merge": {
      "main": [
            "node": "Telegram1",
            "type": "main",
            "index": 0
    "Telegram1": {
      "main": [
    "Every day at 9am": {
      "main": [
            "type": "main",
            "index": 0
            "type": "main",
            "index": 0
  "pinData": {},
  "meta": {
    "instanceId": "2e218fecf5c04a88437ae39a19ce9dbf066b10b553090cad3b6cca6305fe75c8"
Hi @Aghori_X welcome to the community!
Please use Merge node in Combine mode and combine by All Possible Combinations,
it should work as expected in your case..
chrome_PA5oMJAWGw
If this solves your problem, kindly mark the reply as the solution :white_check_mark::folded_hands:t2:
Thank you it is resolved
