[n8n.io - Workflow Automation]
i am not able to pass title from the first node into wordpress node
Hi, can you please share your workflow so we can see it?
Reg
J.
Hi, it would not work like that.
Please go into your GUI and open up the workflow
select all the nodes inside the workflow (copy everything ctrl-c)
come to the forum and post your workflow inside a code segment
in a message via paste (ctrl-v)
it should appear interactive in the preview if everything is fine.
reg,
j.
Hi,
You would probably need to add a merge node after your set title and before the end result.
reg,
J.
didnt work and i cant even paste post workflow again it says only 5 links for new users
Hi,
you probably need to set it to ‘combine’ and ‘position’
reg
j.
