Not receiving startTime and endTime values from GoHighLevel appointment fetch in HTTP Request node
I’m using n8n to fetch appointment data from GoHighLevel after a contact books via a calendar form. Everything works — the contact details, tags, and response come through — but I’m not receiving the actual appointment time (startTime, endTime) in the HTTP Request response. This is blocking a voice call reminder via Vapi, which relies on the exact appointment time.
There is no error — the request is successful, but the appointments array is empty.
  "appointments": []
Expected at least one item with:
  "startTime": "...",
  "endTime": "...",
hello @Pratyaksh
are you sure that the appointments exist between Saturday 02:40 UTC and Sunday 02:40 UTC? Anyway seems that’s an issue with gohighlevel and not with n8n.
