Hello. For some reasons, Notion Node omits the text after “Copy of” prefix for copied records.
Notion table:
Notion Node,
The effects disappears after any change in the text following “Copy of…”
Notion table:
Notion Node,
Hey, Artem! This is Notion API / architecture issue, not n8n Notion Node. You can find missing part as one more text object in plain text, if you switch simple output off.
What a pity! Thank you.
