Problem: Number Format causes errors but text based number work using .toString. without decimal point. Has anyone else had this issue? Am I missing something?
Thank you in advance!!
Screenshot: “quantity” as a text field accepts data using .toString()
Could you check whether your data is by any chance a string rather than a floating point number? You can see this by enabling the JSON view shown in the screenshot above on the node your Notion node retrieves data from.
If so, you could convert your string into a floating point number when passing it on to Notion by adding parseFloat() to your expression like so:
