O1 system prompt in n8n
Why is it not possible possible to use o1 system prompt ? only in conversational, but this way the output is bad.
He doenst understands the context .
  • **n8n version:**1.76.1
  • Database (default: SQLite): dont understand
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):**default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):**n8n cloud
  • Operating system:?? windows
Hey @Jan_Liefooghe Welcome to the community!
This is an OpenAI spec change with their reasoning models. See https://platform.openai.com/docs/guides/reasoning#advice-on-prompting
Hi Jim,
Thank you for the welcome. Leaning every day. Also love some of you work you allready made. Definatly on my top 10 list.
But do you mean , readin gtroughout the spec, o1 mini cn 't be selected as ad syste role? in n8n?
Even a simple model I add (excluding saying system, conversational…) with o1 is not working. Do I need to add some JSON code to make is running, like in the liks you are referring to?
Kind regads,
Jan (chemist engineer… no coder here, yet)
