OAUTH issue while running n8n docker behind cloudflared CDN
When running n8n in docker and exposing it via CDN (Cloudflared) one cannot configure correct oauth callback URL
Internet → https://public-url:443 → Cloudflared tunnel forward to http://localhost:5678 → docker foward port :5678:5678 into n8n docker.
URL callback generated by N8N for OAUTH is "https://public-url:5678/rest/oauth2-credential/callback
which is not handled by Cloudflare.
In docker settings one might change the environments to
-e N8N_HOST=“public-rurl”
-e N8N_PROTOCOL=“https”
-e N8N_PORT=“443”
-e WEBHOOK_TUNNEL_URL=“public-url”
-e VUE_APP_URL_BASE_API=“public-url” \
which causes whole n8n in docker to run on port 443.
Expected behaviour is to have environment variable just changes URL:port for OAUTH URL callback.
The only solution to make OAUTH working behind CDN is to switch N8N to port 443 or to have Cloudflare CDN forwarding port 5678 from public access (not recommended by security).
OAuth 501 time out
sudo docker exec -it n8n env | grep -E “N8N|VUE_APP”
N8N_HOST=n8n.maziak.eu
N8N_PROTOCOL=https
N8N_PORT=5678
VUE_APP_URL_BASE_API=https://n8n.maziak.eu
N8N_VERSION=1.74.3
N8N_RELEASE_TYPE=stable
Runnint in Docker
Debian Linux
Any news on the case? Same problem happening here…
