I wanted to ask you if there is a way for example that I can access from the column “Monday” to the result 14,022 of the input and in the output place that result in a certain column as a variable. I know that today it brings me all the first row of KPIs but I would like to know if I can access the results of the second row “Acquisitions”.
The purpose of having multiple items is so you can loop over it. If you only need the one datapoint you may want to fetch just that, but it depends on the rest of your workflow and your use case.
The simplest way to get that data would be to filter it with an if like below:
Then in the true brand it will have just the values from the row you filtered to.
Keep in mind, in order to access the rest of the data from this point you will need to merge the rest of the data back in, which i included in there. If you don’t need that data again you can just delete the merge
Let me know if this doesnt make sense or doesnt answer your question
