Hi,
I’m setting up an OIDC server to work with n8n. Everything was working fine, but after I changed the User role provisioning setting to “Instance and project roles”, new users are no longer able to log in.
Interestingly, the login still works perfectly for users who already exist in the system. It seems like the automatic provisioning for new accounts is failing under this specific role setting.
Could you help me identify what could cause the error?
Thanks!
{"code":0,"message":"insert or update on table \"project_relation\" violates foreign key constraint \"FK_5f0643f6717905a05164090dde7\"","stacktrace":"QueryFailedError: insert or update on table \"project_relation\" violates foreign key constraint \"FK_5f0643f6717905a05164090dde7\"\n at PostgresQueryRunner.query (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/driver/postgres/PostgresQueryRunner.ts:331:19)\n at processTicksAndRejections (node:internal/process/task_queues:105:5)\n at InsertQueryBuilder.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/query-builder/InsertQueryBuilder.ts:142:33)\n at SubjectExecutor.executeInsertOperations (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/persistence/SubjectExecutor.ts:385:38)\n at SubjectExecutor.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/persistence/SubjectExecutor.ts:134:9)\n at EntityPersistExecutor.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/persistence/EntityPersistExecutor.ts:182:21)\n at ProjectService.addUser (/usr/local/lib/node_modules/n8n/src/services/project.service.ee.ts:584:10)\n at /usr/local/lib/node_modules/n8n/src/modules/provisioning.ee/provisioning.service.ee.ts:251:5\n at EntityManager.transaction (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+typeorm@0.3.20-15_@sentry+node@9.42.1_mysql2@3.15.0_pg@8.12.0_sqlite3@5.1.7/node_modules/src/entity-manager/EntityManager.ts:152:28)\n at ProvisioningService.provisionProjectRolesForUser (/usr/local/lib/node_modules/n8n/src/modules/provisioning.ee/provisioning.service.ee.ts:245:3)"}
docker logs:
n8n-main | 15:25:38.366 error insert or update on table “project_relation” violates foreign key constraint “FK_5f0643f6717905a05164090dde7” { “file”: “error-reporter.js”, “function”: “defaultReport” }
- n8n version: 2.4.4
- Database (default: SQLite): PostgreSQL
- Operating system: MacOS 26.3
