Ok - I understood that webhooks do not work with a self-hosted n8n
but can I assume that the enterprise version can be self-hosted AND make use of webhooks? (and whatsapp Trigger?)
Hi,
Good news :slight_smile:
You misunderstood. Webhooks will work with all n8n instances as long as you set it up properly.
ok, cool - can you give me a hint to the right direction? I studied the documentation without success. I thought setting up the docker container with “start --tunnel” would help, but no… (apart from the fact that it is not recommended for production).
Currently the webhook shows http://localhost:5678/… instead of https://n8n.mydomain.com/
you need to set the
WEBHOOK_URL
ENV variable to whatever your domain is.
wow, you saved my life - thank you!!
