Old Edit Field Node Values are Persisting
I updated the value of a field in a “Edit fields” node yesterday for one of my workflows but had some runs today use the old value, while some used the new correct value. I’ve never had this issue before. I’m on version
1.104.1
Hi there,
I see that the old values are persisting for the Edit Fields node. Have you considered upgrading n8n to latest 1.113.1 and then checking if the behaviour persists? I do recommend taking a backup prior to performing an update.
Cheers!
Thanks for the quick reply! Yes I’m planning on upgrading soon, especially because I keep getting “Critical update” warnings in the editor. Is this specific problem addressed in the newer versions?
I am not seeing anything specific at Release notes | n8n Docs, but I still recommend backup and update followed by testing.
