The idea is:
Create node update button. Keep the same parameters (would apply to any node with lower version).
My use case:
When copying nodes from versions prior to the current one, there is no automatic update when pasted.
Avoid the manual work of creating a new node, replicating the same parameters (especially when the node has a lot of parameters). Also helping when there is more than one old node that needs to be updated.
No!
Unfortunately, I don’t have the knowledge to help with programming.
Below is an image demonstration of how it works.
