I’m not sure how to use OpenAI to generate social media content on n8n platform??
@hecai
Welcome to our community
Please visit: Tutorials - n8n Community
Thank you very much. Appreciate it
Hi @hecai Welcome!
I think for now if you are looking for a template flow below it is:
Also for now if you are unclear please learning on how to build these things by learning how n8n works, see this:
And when you know how to build flows, now you can build anything you desire!
Hello. Yes. Indeed. Going through the tutorials and will follow up with those.
Do you think it’s just hands on ? Or just repeated repetitions ?
Thanks.
@hecai it is very hands on, level 1 & level 2 courses will make you go through a separate process of creating multiple workflows, and those are really good, and also n8n is working on their very professional courses, also so they can be live anytime soon, so register yourself here:
And also for now you should be focusing on getting the basics right and once that is done basically level 1 course, now you can move forward to this section and get more knowledge related to what you wanted to build:
And so you will eventually get to what you wanted to build alongside a very powerful skill!
Hello. Thanks. I’m currently grappling with the Level 2 course; however, I might have to go back to review Level 1 course. I believe my deficiencies with JavaScripts is affecting my learning.
I’m currently in the beginning of level 2 where they are discussing an array of objects.
does the courses include java script lessons?
