Optimizing document extraction pipelines: descriptions, confidence scoring, and error handling
:waving_hand: Hey n8n Community,
I just published a walkthrough on optimizing document extraction and classification pipelines in n8n, and wanted to share the main takeaways here for anyone who’d rather skim than watch.
The video uses the easybits Extractor as the example, but most of these patterns apply broadly to any LLM-based extraction setup you’re building in n8n.
The three areas I cover are description optimization, confidence scoring, and error handling. Each one fixes a different failure mode I see come up repeatedly in the community.
On descriptions
Auto-mapping handles most use cases out of the box, but the moment you hit an edge case (different invoice layouts from different vendors, for example), you’ll want to refine the description for that specific data point. My approach is to paste the current description into an LLM along with two or three example documents that broke the extraction, and ask it to produce a refined version that handles those formats. Drop the refined description back in, run a test, and you’re usually good. The example field is also underused – it’s not just decoration, the extractor uses it to understand the expected output format, so always fill it in when you’re already optimizing.
On confidence scoring
The biggest mistake I see is trying to use numeric confidence values between 0 and 1. The problem is that LLMs don’t really differentiate between 0.8 and 0.9 in any consistent way – running the same document twice can give you different numbers, even though the model’s actual confidence is the same. What works much better is asking the model to return one of three tiers: low, mid, or high. It’s easier for the model to commit to a clear category, and your downstream routing logic becomes a clean Switch node instead of a bunch of fragile threshold comparisons.
On error handling
The extractor already returns null or empty values by default when it can’t confidently identify a data point, which is the right behavior – but I’ve found it useful to reinforce this explicitly in the description as a safety net. A short instruction along the lines of “return null if this value can’t be clearly identified” makes the behavior more consistent across edge cases. From there, the null becomes your signal in the workflow – you can route it to a Slack channel for human review, or log it to a Google Sheet to review the patterns later. Both approaches surface the edge cases instead of letting them silently corrupt your downstream data.
Two workflow templates you can import directly:
Classification with confidence scoring routing → Classify documents and score confidence with easybits Extractor and Slack | n8n workflow template
Error handling with null detection → Catch failed invoice extractions with easybits, Slack, and Google Drive | n8n workflow template
Both are set up so you can import, swap in your own credentials, and start adapting them to your use case. If you run into anything weird while adapting them, drop a reply here and I’ll help out.
Best,
Felix
