I’m using declarative style to build my new node. I have a options
type component that should add some queries to the request. But regardless of what option I select, nothing appears in the output.
This is the output:
?gadget=Skyroom&action=GetUsersN8N&from=&limit=1&offset=4&api_key=apikey-111111111111111111111111
And this is my properties part:
properties: [
displayName: 'From Date',
type: 'dateTime',
default: '',
description: 'Returns customers that are created newer that this time',
routing: { send: { property: 'from' } },
displayName: 'Customer Type',
type: 'options',
default: '',
options: [
displayName: 'All',
value: '',
routing: { send: { property: 'type', type: 'query' } },
displayName: 'Free',
value: 'free',
// action: 'Return customers with free plan',
displayName: 'Paid',
value: 'paid',
displayName: 'Page Size',
description: 'Count of customers to retrieve in each page',
type: 'number',
default: 100,
typeOptions: { minValue: 1, maxValue: 10000 },
routing: { send: { property: 'limit' } },
displayName: 'Page',
description: 'The current page of pagination',
type: 'number',
default: 1,
routing: {
send: {
property: 'offset',
value: '={{($parameter["page"] -1) * $parameter["pageSize"] }}',
- n8n version: 0.209.3
