Outlook 365 filter query - problem with filtering messages by categories that start with specific words
I’m trying to limit messages that are received by Microsoft Outlook 365 node. I want to receive only messages that have a category that starts with ‘test-’.
Problem is that those filter queries do not work and I get the message “The query filter contains one or more invalid nodes.”.
Filter query that works:
categories/any(a:a eq ‘test-’)
Filter queries that do not work, but they should:
categories/any(a:startswith(a,'test-'))
categories/any(a:contains(a,'test-'))
  "errorMessage": "The query filter contains one or more invalid nodes.",
  "errorDetails": {
    "rawErrorMessage": [
      "400 - {\"error\":{\"code\":\"ErrorInvalidUrlQueryFilter\",\"message\":\"The query filter contains one or more invalid nodes.\"}}"
    "httpCode": "400"
  "n8nDetails": {
    "nodeName": "Microsoft Outlook",
    "nodeType": "n8n-nodes-base.microsoftOutlook",
    "nodeVersion": 2,
    "resource": "message",
    "operation": "getAll",
    "itemIndex": 0,
    "time": "16.04.2024, 18:07:08",
    "n8nVersion": "1.36.4 (Self Hosted)",
    "binaryDataMode": "default",
    "stackTrace": [
      "NodeApiError: The query filter contains one or more invalid nodes.",
      "    at Object.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1264:19)",
      "    at processTicksAndRejections (node:internal/process/task_queues:95:5)",
      "    at Object.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1986:20)",
      "    at Object.microsoftApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Microsoft/Outlook/v2/transport/index.js:28:16)",
      "    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Microsoft/Outlook/v2/actions/message/getAll.operation.js:252:24)",
      "    at Object.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Microsoft/Outlook/v2/actions/router.js:69:36)",
      "    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Microsoft/Outlook/v2/MicrosoftOutlookV2.node.js:16:16)",
      "    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19)",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:53",
      "    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20"
  • n8n version: 1.36.4
  • Operating system: Ubuntu 22.04.4
hello @ofc_edu
Well… the proper syntax is startsWith, but it seems that it’s not supported for categories property
startswith(subject,'info') works, but with subject property.
categories/any(a:a eq 'test-') also works, but I need to find all emails with category name that start (or at least contain) that word, as category full name is generated dynamically (usually they look like test-x7ds8aCD ), so equal is not the solution for my case.
It seems that this is Microsoft Graph query problem, not this specific node problem. I’m trying to get the proper syntax from MS Graph forum, will post if I get it.
In the end it seems that indeed startswith is not supported for categories property.
