I am trying to collect my share of expense from SPLITWISE (an application) using API token key. After the http node, i added the split node as per the suggestion and later added the function node - but the output for the function node is empty. Adding pictures of each nodes, please help.
Hey @Vallabhee_Rungta hope all is well, welcome to the community,
See if the following workflow can help:
I used static data, which simulates the response from splitwise (or it’s pretty close).
The final result is a list of expenses which includes the user_id in question (set in myID node) and its owed share.
