Override Credentials' values with env vars
The idea is:
In the UI, let credentials have fields overridden from key-value sources, such as env vars, .properties files or what-have-you.
This would make overriding env vars a first-principles concept rather than forcing people to use the $ENV['var'] hack everywhere, like Loading credentials fields from environment variables - #2 by jan or numerous other questions.
My use case:
12factor app architecture, separation of environments between dev/stage/prod.
It would make OK security the default rather than something you have to search this forum for and manually handle.
Not at this point
