Paginate within json body
I´m trying to paginate through this api. pageNumber is set in the json body and I´ m. trying to use the pagination from the http request node. But setting Query to pageNumber and referencing it from the response doesn’t work:
“jsonBody”: “{"userId":"c7a43a70-8e8e-41dc-b7da-ad2ed4fe950e","projectId":"90d090ac-b5fd-460f-8ecc-a1b0d8dbf1ad","pageId":"98bc1d6d-b05f-4a80-bad0-4f9fdf68ffb7","isStandalone":false,"locale":"de","isActiveCustomJobPages":true,"isUseLayoutsOfSubsidiaries":false,"filterStatus":{"careerLevel":false,"category":true,"partnership":false,"location":true},"pageNumber":1,"numberOfJobsOnPage":12,"listState":{"search":"","location":{},"filters":{},"filterPredictions":{}},"jobListTitleNew":"Neu","isGetFilters":true,"isForCurrentLocale":false}”,
response contains:
“pagination”: {
“dataSource”: [
1,
2,
3,
4,
5,
6,
7
  • **n8n version:1.21.1
  • **Database (default: SQLite):SQLite
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
  • **Operating system:AWS AMI 2023
Hey @Kool_Baudrillard,
this api has no standard pagination feature, so it is not possible to do pagination within the http node.
You can solve it by doing a loop like this:
In the node Set Request Body it is necessary to change the page dynamically on the runIndex which represents the current loop execution.
After looping you have to aggregate the results of the loop by the code node named Aggregate Results
Cheers.
thx,
that´s what I had in mind, if pagination didn´t work out!.
